Save monolithic jt from NX to Teamcenter
Hello ,
I am looking for a way to enable saving monolithic jt for assemblies  in Teamcenter .
I believe that requires creating a new type of tool or dataset  from BMIDE with specific comportament?
If anyone has done it before , i would gladly apreciate some guiding .
Thank you .
Re: Save monolithic jt from NX to Teamcenter
You might need new object under DirectModel as parent, with Reference and Tool.
Use dispatcher with run bat script ugtopv and make sure you have load options set for dispatcher so that it will be loaded as new datasettype under ItemRevision.
If not dispatcher use only data model changes, and the user will create new dataset and loads the monolithic Jt under named references.
Hope this helps.
With regards,
Chini
