Do you mean
Reply
Solved! Go to solution
Saved Searches are missing from the Advanced Search tab --- AWC
[ Edited ]
Is there someone who could let me know how the Saved Searches (aka. "Advanced Search") could be activated in Active Workspace (AWC).
As shown in this video:  https://docs.plm.automation.siemens.com/tdoc/aw/3.2/aw_html_collection#uid:xid1318284.
Thank you in advance.
ZsCsaba
Software Engineer
Re: Saved Searches are missing from the Advanced Search tab --- AWC
[ Edited ]
Did you check the preference mentioned in your link?
Setting AW_Advanced_Search_Visibility to a value of true (the default) enables the Advanced Search link beneath the global search box and allows the Advanced Search tab to be displayed as part of the Search tab set. Setting AW_Advanced_Search_Visibility to a value of false removes the link and tab.
https://docs.plm.automation.siemens.com/tdoc/aw/3.2/aw_html_collection#uid:xid1316813
Thank you for your response.
Yes, I know, and I've tried this preference, but as you've also described, this preference sets the visibility of the Advanced Search link and Advanced Search tab. I've created the screenshot about the Advanced Search tab, so it's visible, and this preference is set properly.
The problem in my environment is that the Saved Searches are missing from the Advanced Search tab. Please see the picture added to the original question.
Br,
ZsCsaba
Software Engineer
Solution
Solution
Accepted by topic author ZsCsaba
‎07-06-2017 06:29 AM
Advanced Search is available for Active Workspace users running on Teamcenter versions 10.1.7 and later or 11.2.3 and later.
Software Engineer
