Seaching Query
Hello!!! There is a task. I would like to find all Item Revisions with such condition:
Item revision is in-process or also Item revision with any status except Rejected. How can i do it? Thanks.
Re: Seach Query
properties "fnd0AllWorkflows" and "release_status_list" should be helpful.
Re: Seaching Query
I found decision.
Important!
Before OR - It's the first searching query, after - the second : i.e. as i need only the material's item revision master forms, then string with type have to be before and after OR.
