Search in AWC results in error
I am using AWC 3.2 1.
After completing the object indexing, when i try to search for an item getting the error.
SS_CFI_path given NULL or empty path name 000007FFFED90700 (Error Code: 65)
Can someone please suggest, how to fix this and get search results.
Phani
Re: Search in AWC results in error
Got the solution for this issue, posting the same, so that it could help someone.
When "Search" is invoked from AWC Client, it will read application versions from the files
%TC_ROOT%\media_teamcenter_activeworkspace.xml
%TC_ROOT%\media_teamcenter_foundation.xml
Make sure this file is available, latest and is not tampered.
Phani
