Security for project and object
Hello ,
I has an issue about the security of the Projects.
The scenario is about to “Assign to Project” functionality for a new part. The user shouldn’t be assign the new created item to wrong Project. In more detail , I have a scenario like this ;
User1 is Design Engineer in both Group A and Group B.
Group A is assigned to Project A.
Group B is assigned to Project B.
While User 1 is creating an object if Group A is active, only Project A should be seen in the “Assign an Object to Project” window and while User 1 is creating an object if Group B is active, only Project B should be seen in the “Assign an Object to Project” window.
If Group A is active, User 1 should see only objects assigned to Project A and Group B is active, User 1 should see only objects assigned to Project B.
How can i manage this scenario in TC 8.3 or TC 11.2?
Best Regards
Gurkan
