Seeing machinin time in rich client window
Hi guys,
I want to see the machining time of an MENCMachiningRevision in rich client window.
I want to put this machining time to an attribute then retrieve from Teamcenter.
I can do the second part but couldn't get to the information of the machining time to hold into an attribute.
I'll then modify the XML stylesheet of MENCMachiningRevision to show the time in Teamcenter.
Cem
Re: Seeing machinin time in rich client window
Run the attached journal on the NC_PROGRAM group to find the name and index of the CAM object parameter.
I ran that selecting the operation and saw this
If I select NC_PROGRAM or PROGRAM GROUP i don't see anything related to machining time.
Anyway, how can it this info be accessed and put into an attribute?
Cycle through the OperationCollection, sum up all the cutting times, format the final result and create a part attribute with that information.
If you use the Operation object, you need to use the GetDoubleValue method of it and the name of the parameter.
You may search the NX customization and programming or the NX manufacturing forum for further information, since this is not a Teamcenter topic per-se.
