cancel
Send an EMAIL from external SOA appication
How to send an email from external SOA application?
I have tried below SOA api but proper explanation is not available in the documentation
EnvelopeService envelopeService = EnvelopeService.getService(Session.getConnection()); envelopeService.sendAndDeleteEnvelopes(new Envelope[] {envelope});
In the above API, how to fill Envelope object?
Re: Send an EMAIL from external SOA appication
copied this from GTAC.
Should work together with the Hello Teamcenter SOA example.
try
		EnvelopeSend envelope = new EnvelopeSend(AppXSession.getConnection());
		if(envelope.createEnvelope())
			envelope.sendEnvelope();
catch (ServiceException e)
		e.printStackTrace();
package com.teamcenter.hello;
import com.teamcenter.schemas.soa._2006_03.exceptions.ServiceException;
import com.teamcenter.services.strong.core.DataManagementService;
import com.teamcenter.services.strong.core.EnvelopeService;
import com.teamcenter.services.strong.core.SessionService;
import com.teamcenter.soa.client.Connection;
import com.teamcenter.soa.client.model.ModelObject;
import com.teamcenter.soa.client.model.ServiceData;
import com.teamcenter.soa.client.model.strong.Envelope;
import com.teamcenter.soa.client.model.strong.User;
import com.teamcenter.soa.exceptions.NotLoadedException;
public class EnvelopeSend
	private EnvelopeService envService;
	private DataManagementService dmService;
	private SessionService session;
	private User user;
	private Envelope envelope;
	public EnvelopeSend(Connection connection) throws ServiceException
		dmService = DataManagementService.getService(connection);
		envService = EnvelopeService.getService(connection);
		session = SessionService.getService(connection);
		user = session.getTCSessionInfo().user;
	public boolean createEnvelope()
		try
			DataManagementService.CreateIn input = new DataManagementService.CreateIn();
			input.clientId = "ID:" + input.hashCode();
			input.data = new DataManagementService.CreateInput();
			input.data.boName = "Envelope";
			input.data.stringProps.put("object_name", "MyEnvelope Message"); // Subject
			input.data.stringProps.put("object_desc", "Message body...");
			input.data.tagArrayProps.put("listOfReceivers", newModelObject[]{ user });
			// To: receivers (User objects)
			input.data.tagArrayProps.put("contents", new ModelObject[]{ user.get_home_folder()}); // attachments (Folder objects)
			DataManagementService.CreateResponse resp = dmService.createObjects(new DataManagementService.CreateIn[]{ input });
			if(!ServiceDataError(resp.serviceData))
				for(DataManagementService.CreateOut out : resp.output)
					for(ModelObject obj : out.objects)
						if(obj instanceof Envelope)
							envelope =(Envelope)obj;
							return true;
		catch(ServiceException e)
		catch (NotLoadedException e)
		return false;
	public void sendEnvelope()
		ServiceData sdata = envService.sendAndDeleteEnvelopes(new Envelope[]{ envelope });
		ServiceDataError(sdata);
	protected boolean ServiceDataError(final ServiceData data)
		if(data.sizeOfPartialErrors() > 0)
			for(int i = 0; i < data.sizeOfPartialErrors(); i++)
				for(String msg : data.getPartialError(i).getMessages())
					System.out.println(msg);
			return true;
		return false;
HTH,
Xtof
Thank you for the replay. I received same solution from GTAC
