Set TC Shell default locale
you start the RAC in German or French environment by using the command: portal.bat -nl de_DE or -nl fr_FR.
How you set the locale for TC utilities in a TC shell  if you need to run a utility in another locale than en_US?
The global constant SiteMasterLanguage is 'de_DE'. I've to import localized attributes where no en_US translation exists. So I've to run the utility in 'de_DE' language.
Michael
Teamcenter UA | NX CAD
11 REPLIES 11
Re: Set TC Shell default locale
Good afternoon, read this topic:
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/How-to-temporarily-d...
I think it can be used with preference TC_language_default
TC_language_default is already set to 'de_DE'
Michael
Try before running utility set environment variable:
set TC_language_default=de_DE
Does not work. Even if I set all three env variables. Opened IR.
set TC_language_data_entry=de_DE
set TC_language_localized_property_value_entry=de_DE
Michael
TC shell is the classic windows cmd shell. May be just set env to corresponding locale using windows shell commands?
CHCP code_page
 for our locale it worked
Thanks alex. The CHCP command is utilized to set the character encoding. This is not a character problem, but a problem of handling the master locale of localized attributes.
My text encoding of imported attribute values is fine.
Michael
TC 11.4.0.3
Michael
It looks like at the moment, I don't know how I can help you. If you opened IR on GTAC, I think you need to wait for their response.
