Setting Release status's using csv2tcxml generated xml file does not display release date
Has anyone seen this before?
I am creating items via csv2txml, but I am having problems with the creation of release status on the Item revision. When I have created the item revision, a status is created, but the release date is not displaying. Then when I send the Item to the structure manager, I get  message stating that:
"There is no configured revision for the given top line item."
My csv file looks like
!Item:item_id|Item:object_name; ItemRevision:object_name|Item:object_type|ItemRevision:item_revision_id|creation_date|last_mod_date|owning_group|owning_user|release_status_list|ReleaseStatus:date_released
X000003|Test Name|Item|A|2001/02/03-04:05:06|2016/10/25-10:43:48|DBA|interface|Approved|2016/10/25-10:43:48
Peter
Re: Setting Release status's using csv2tcxml generated xml file does not display release date
I did not test it but I'd try to use ItemRevision:date_released instead of ReleaseStatus:date_released.
xtof
That was it. Tested and confirmed.
I logged a call with GTAC who provided the same answer.
Peter
