Shared Metadata Cache login error
Appreciate any information about the attached login error.
Only system change is a custom DLL that I put into TC_BIN.
However,  I removed the custom DLL from TC_BIN,  and I still get the error.
9 REPLIES 9
Re: Shared Metadata Cache login error
You need to set TC_SKIP_CLIENT_CACHE=1 in portal.bat or fix the root cause on the server...
# Delete
generate_metadata_cache -u=infodba -p=infodba -g=dba -delete
generate_client_meta_cache -u=infodba -p=infodba -g=dba -t delete all
# Regenerate
generate_client_meta_cache -u=infodba -p=infodba -g=dba -t generate all
generate_metadata_cache -u=infodba -p=infodba -g=dba -force
Evaluating: AW 3.4
Appreciate your response.
Below is my console when trying to run [generate_client_meta_cache].   infodba/infodba/dba is the correct values.
C:\Apps\Teamcenter11\tc_menu>generate_client_meta_cache -u=infodba -p=infodba -g=dba -t generate all
Processing database [tc]
Problem logging in. Caught an exception!
Error -1: Login failed.
ERROR - Login failed!
Usage: $TC_ROOT/bin/generate_client_meta_cache -u=<admin_user> -p=<password> -g=<group> [<-option>] [<cmd>] [<cache>]
    [-pf=<password file>]
    [-log=<log file name>]
    [-delta=<delta file name>]
    [-l1=<language 1>]
    [-l2=<language 2>]
    [-err=<errfile name>]
    [-t]
    [-h]
Where:
    <cmd> operation to perform on the client cache
        generate <cache>    generate or regenerate the client cache
        update   <cache>    update or generate the client cache as needed
        delete   <cache>    delete the client cache
        report              report on the state of the client cache
        tickets  <cache>    display tickets for the feature(s)
        context             check context for conditions
    <cache> the client cache to work on
        all                             all of the client cache files (default)
        types                           types cache
        lovs                            lovs cache
        icons                           icons cache
        stylesheets                     style sheets cache
        textservers                     text server cache
        contextmenusuppressionrules     context menu suppression rules cache
    <-option> the options for processing
        -log        log file name       default log written to the TEMP directory
        -delta      delta file name     file containing the changes in the database for update (not supported)
        -l1         language            specific language to get tickets for
        -l2         language            specific language to get tickets for
        -err        errfile name        default err written to the TEMP directory
        -t          timings             time function calls
        -remote                         remote start, generate log files
        -h                              print this usage message
    Example languages to get tickets for, none is all
        en_US           English (United States)
        de_DE           German
        es_ES           Spanish
        fr_FR           French
        it_IT           Italian
        pt_BR           Portugese (Brazil)
        cs_CZ           Czech
        pl_PL           Polish
        ru_RU           Russian
        ko_KR           Korean
        ja_JP           Japanese
        zh_TW           Chinese (Taiwan)
        zh_CN           Chinese (PRC)
    This program manages the shared client cache folders and files.
Did you copy/paste the command instead of typing it in? The "-" and "=" can get you in trouble when copy/paste is used. Try typing the command in yourself. Further, if you changed the infodba password then use your real password instead of the default.
Evaluating: AW 3.4
ok,  maybe some progress :)
I deleted all the Teamcenter cache directories under %temp% : FCCCache, Siemens, Teamcenter.
The cache login error is gone,  and now I get the login POM error,  which also appears to be affecting Randy's cmd recommendation:
"C:\Apps\Teamcenter11\tc_menu>generate_metadata_cache -u=infodba -p=infodba -g=dba -delete
Command line login fail! Error code = 26052 (POM_db_connect_fail) "
See attached.   Appreciate any more feedback anyone may have.
Either something isn't sourced correctly when running the tc menu script or your database is unavailable (not started or connection string in tc_profilevars.bat is wrong). Validate your DB connection by running in a Tc cmd window:
install -ayt
You should see "Site is already installed". Anything else and you have a DB connection issue.
Evaluating: AW 3.4
I restarted the Oracle listener and Teamcenter is up now.   I have no idea how simply restarting the listener got me past the POM login error.   Only thing I can think of is startup order -
was (manual ):
OracleServiceTC
OracleOraDb11g_home1TNSListener
OracleMTSRecoveryService
now ( with the listener restart):
OracleServiceTC
Start the listener before the DB instance.
Evaluating: AW 3.4
