Shared Metadata Cache version problem
Builder
Builder
Hi there
Today I had a problem with Shared Metadata Cache version as follow:
The Shared Metadata Cache is out of date. The dataset version 16 is older than the version 18 which is deployed in the database, so Metadata is populated locally in this process. The "generate_metadata_cache" utility will re-generate the Shared Metadata Cache.
I've used to "generate_metadata_cache" with delete and force switches but not solved.
Any sugesstion?
11 REPLIES 11
Re: Shared Metadata Cache version problem
Good afternoon, try re-generate server and client caches, as example:
1) Delete Client Metacache
   generate_client_meta_cache -u=infodba -p=infodba -g=dba -t delete all
2) Generate Server Metacache
   generate_metadata_cache -u=infodba -p=infodba -g=dba -force
3) Generate Client Metacache
   generate_client_meta_cache -u=infodba -p=infodba -g=dba -t generate all
Builder
Builder
Unfortunately the problem still exists. Same error after regeneration appeared.
Then try this:
1) stop Server manager process and delete Shared Memory Folder
%TEMP%\V11xxxxxx
2) re-generate server and client caches from my previous post
3) Restarted Pool manager and try log to client
Builder
Builder
Not solved. Same error again.
Is the owner of the TC folders the same as the user that is running the services?
Builder
Builder
Yeah, both of them are Administrator.
What is the user that is generate the cache?
Builder
Builder
This is "infodba"
Are you logged in as infodba or Administrator?
I had this issue but it was because of a mismatch between the installing user/ services users/ logged in user. Once that was all the same (plus turning off shared cache), then it worked after regenerating the cache.
