Re: Shared Metadata Cache version problem
Builder
Builder
Thanks, I've installed TC as system Administrator, so at the current time I've not access to TC organization to set DBA for system administrator and running cache regeneration.
I made an infodba user in system to run Tc services and and command but the below error appeared:
Command line login fail, error code 26044, POM_start_not_yet_called
My DB is MSSQL.
