Siemens JT Translator documentation
 Where can I find the documentation of the Siemens JT Translator? I want to implement two translators to convert the JT to CATPart and JT to CGR specifically using this translator. Is this same as JtToCatiaV5??
Akshay
4 REPLIES 4
Re: Siemens JT Translator documentation
There isn't a generic JT translator that I'm aware of and each CAD system will have their own. Some are bi-directional while others are just CAD to TC. For Catia, it is "JT Bi-Directional Translator for CATIA V5" which is a separate download from Siemens. The docs are in the download.
Evaluating: AW 3.4
Hello @RandyEllsworth
Thanks a lot for your reply. I think this is what I was searching for. I can move ahead now searching the documentation and implementing the requirement.
Akshay
Can you please share the link for the download of the JT Bi-Directional Translator?
Hello;
go to GTAG--> Siemens PLM Download Server--> Teamcenter Visualization/ JT Translators/ PLM Vis(left side of the screen) --> Full Products -->JT Translators -->Catia V5
The latest version is 13.1 :
PLM_Components_JT_Bidirectional_Translator_for_CATIAV5_v13.1_64bit.zip
Good luck.
