Solid Edge ST10 error: SEEC_Default_Item_Type has invalid value...
Hello Experts,
any idea how to get rid of the error ?
Current value is:
Item
Item.
Re: Solid Edge ST10 error: SEEC_Default_Item_Type has invalid value...
Check the value(s) of SEEC_ItemTypelist_*
Looks like an old problem with plenty of PR's.
Thanks Randy. Setting values to all those preferences solved the problem.
