Solid Tool Assembly display in managed NX CAM
I´d like to display the solid tool assembly in tool path visulization. I tried it with the OOTB Tool shipped with NX but I do not get it to work. The 3D-Solids are not shown.
I also tried to import the Tool-Assembly to Teamcenter but no results.
Is it possible to use the solid tool display in Managed NX without MRL?
If Yes, Is there an overview or documentation how to setup this?
working with NX11.0.1, Teamcenter 10.1
Andre
Re: Solid Tool Assembly display in managed NX CAM
You may want to ask your question to the NXCam-discuss group.
Evaluating: AW 3.4
Hello Mr. Ellsworth,
Yes you are right, this would be the better place to dicuss that topic
Andre
