SolidEdge Add-in in Structure Manager
Hello Guys,
As you know if you select an item revision then send to structure manager , you can easily open that item revision by NX icon (that is located on toolbar). However , i want to add SolidEdge icon to reach item revision in Structure Manager without going back to My Teamcenter. How can i add it ? Could you help me please ?
Best Regards
Gurkan
Re: SolidEdge Add-in in Structure Manager
The SE button on the toolbar is new and hasn't always been there. I'd say you should log an IR because it seems they missed it.
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Hi Jaime ,
Thanks for response. Yes i think so , they missed it. I opened IR and report it to GTAC.
Best Regards
Gurkan
Give me the IR and I'll add my name.
Jamie
