Solidworks Assembly Migration in Teamcenter
Hello All,
Can we use swimimport utility to import solidworks assembly with all its child parts saved separately?
and how to use it?
Currently i can import individual parts using this utility.
Re: Solidworks Assembly Migration in Teamcenter
Please follow below steps to import assembly file with child parts.
Syntax:
swimimport -login -u <username> -p <password> -g <group> -log <logfile> -overwrite <C:\input.txt>
input.txt is instruction file.
In input.txt file you need to define the exact path of the soildworks files saves on local drive.
"C:\Test_asm\My_asm.SLDASM" item_id=000037 item_revision_id=A item_name="My_asm" item_type=Item
"C:\Test_asm\Base01.SLDPRT" item_id=000034 item_revision_id=A item_name="Base01" item_type=Item
"C:\Test_asm\Bolt0002.SLDPRT" item_id=000035 item_revision_id=A item_name="Bolt0002" item_type=Item
I am Trying to run some tests importing SW parts to TC 11.2.3 by running swimimport.bat, after running the utility inmmediatly send the output BulkLoad operation has finished, and no log file is being generated despite the fact that I am indicating it
this is the what I am writing in cmd line
D:\Teamcenter11\swim>swimimport.bat -ramonm -ramonm -dba -log="D:\14.DM_Tools\sldprt_import.log" -overwrite "D:\14.DM_tools\swim_instruction.txt"
This is what I am getting
These are my two sldprts  on my instruction file that I am trying o import using the utility:
"D:\14.DM_tools\5112-ANT-LT\13360073.034093_rA1.sldprt" item_id=034093 item_revision_id=A item_name="Test_SW" item_type=Item model_type=sldprt
"D:\14.DM_tools\5112-ANT-LT\13360026.034094_rA1.SLDPRT" item_id=034094 item_revision_id=A item_name="Test_SW2" item_type=Item model_type=sldprt
Do you have any clue? why is not importing the sw parts into Teamcenter
Thanks in Advance
Use the teamcenter searche function:
Search item_id : 034093
or
Search the name : 13360073.034093_rA1.sldprt
Builder
Builder
I am trying to import a drawing and its dependents. Below is my command & input file.
swimimport.bat -u=movedata -p=movedata -g="dba" -overwrite -log="D:\SolidworksImport\ImportDRW.log" "D:\SolidworksImport\SwimInputDRW.txt"
"D:\RH1_Content1\ALL_Solidowrks\y01e7100.sldprt" item_id="3000060001" item_revision_id="A" item_type="Item"
"D:\RH1_Content1\ALL_Solidowrks\y10e8100.sldprt" item_id="3000060002" item_revision_id="A" item_type="Item"
"D:\RH1_Content1\ALL_Solidowrks\y01e8051.sldprt" item_id="3000060003" item_revision_id="A" item_type="Item"
"D:\RH1_Content1\ALL_Solidowrks\y01e7002.sldasm" item_id="3000060004" item_revision_id="A" item_type="Item"
"D:\RH1_Content1\ALL_Solidowrks\y01e8002.sldasm" item_id="3000060005" item_revision_id="A" item_type="Item"
"D:\RH1_Content1\ALL_Solidowrks\h01a1800.sldprt" item_id="3000060006" item_revision_id="A" item_type="Item"
"D:\RH1_Content1\ALL_Solidowrks\y01e0400.slddrw" item_id="3000060007" item_revision_id="A" item_type="Item"
"D:\RH1_Content1\ALL_Solidowrks\y01e7051.sldprt" item_id="3000060008" item_revision_id="A" item_type="Item"
When i finish the import i see two datasets under same itemRevision.
I am wondering why two datasets are getting created ? Any suggestions would help. Really bugging me out here.
Santosh
I searched it, and it wasn't imported into TC.
Thanks!
Have you tried -dry_run  combined with -output? Using this you will be able to review an instruction file prior executing the import.
Builder
Builder
Yes. I used the same output file generated using dry_run as input. I changed only the item_id and removed other irrelevant details.
Santosh
