Solidworks to TC 10.1.3 integration
Hi guys,
Anyone integrated Solidworks to TC?
Should I install Solidworks also on the TC corporate server?
Cem
Re: Solidworks to TC 10.1.3 integration
You only need to install Solidworks on a server if you plan to use Dispatcher with it.
Larry Carpenter, P.E.
Thanks Larry!
