Solr errors when I attempt quick search in Active Workspace
I've recently been having problems with the quick search of Active Workspace (the bar on the top right). It doesn't show suggestions and it doesn't find anything when I click on search.
I looked the logs in Solr and I found this
I found out that every time I try to search for something here appears a new error.
This is the text from when I expand an error:
org.apache.solr.common.SolrException: undefined field TC_0Y0_FTS
	at org.apache.solr.schema.IndexSchema.getDynamicFieldType(IndexSchema.java:1300)
	at org.apache.solr.schema.IndexSchema$SolrQueryAnalyzer.getWrappedAnalyzer(IndexSchema.java:452)
	at org.apache.lucene.analysis.DelegatingAnalyzerWrapper$DelegatingReuseStrategy.getReusableComponents(DelegatingAnalyzerWrapper.java:74)
	at org.apache.lucene.analysis.Analyzer.tokenStream(Analyzer.java:191)
	at org.apache.lucene.util.QueryBuilder.createFieldQuery(QueryBuilder.java:206)
	at org.apache.solr.parser.SolrQueryParserBase.newFieldQuery(SolrQueryParserBase.java:371)
	at org.apache.solr.parser.SolrQueryParserBase.getFieldQuery(SolrQueryParserBase.java:741)
	at org.apache.solr.parser.SolrQueryParserBase.handleBareTokenQuery(SolrQueryParserBase.java:529)
	at org.apache.solr.parser.QueryParser.Term(QueryParser.java:309)
	at org.apache.solr.parser.QueryParser.Clause(QueryParser.java:180)
	at org.apache.solr.parser.QueryParser.Query(QueryParser.java:101)
	at org.apache.solr.parser.QueryParser.Clause(QueryParser.java:184)
	at org.apache.solr.parser.QueryParser.TopLevelQuery(QueryParser.java:90)
	at org.apache.solr.parser.SolrQueryParserBase.parse(SolrQueryParserBase.java:152)
	at org.apache.solr.search.LuceneQParser.parse(LuceneQParser.java:50)
	at org.apache.solr.search.QParser.getQuery(QParser.java:140)
	at org.apache.solr.search.BoostQParserPlugin$1.parse(BoostQParserPlugin.java:54)
	at org.apache.solr.handler.component.QueryComponent.prepare(QueryComponent.java:161)
	at org.apache.solr.handler.component.SearchHandler.handleRequestBody(SearchHandler.java:269)
	at org.apache.solr.handler.RequestHandlerBase.handleRequest(RequestHandlerBase.java:154)
	at org.apache.solr.core.SolrCore.execute(SolrCore.java:2089)
	at org.apache.solr.servlet.HttpSolrCall.execute(HttpSolrCall.java:652)
	at org.apache.solr.servlet.HttpSolrCall.call(HttpSolrCall.java:459)
	at org.apache.solr.servlet.SolrDispatchFilter.doFilter(SolrDispatchFilter.java:257)
	at org.apache.solr.servlet.SolrDispatchFilter.doFilter(SolrDispatchFilter.java:208)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1668)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:513)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:213)
	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:119)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
	at org.eclipse.jetty.server.Server.handle(Server.java:518)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
	at java.lang.Thread.run(Unknown Source)
Have you encounter this? Or do you have ideas how to fix this?
3 REPLIES 3
Re: Solr errors when I attempt quick search in Active Workspace
Siemens Legend Siemens Legend
Siemens Legend
did it ever work?
if yes, have you deployed a new or changed datamodel recently?
if yes, have you followed the steps mentioned in our docs: https://docs.plm.automation.siemens.com/tdoc/aw/4.0/aw_html_collection#uid:xid1284832:index_SearchIn...
No, it never worked.
Siemens Legend
please follow the steps in the documentation - link provided in last post
if you need help - just tell us
