Spatial filter activate
Hello Everyone,
how to activate the spatial filter in TeamCenter (in Struture Manager)?
Regards.
Re: Spatial filter activate
Cacheless seach is already deployed and product-scoped cs enabled. Spatial filter is still inactive.
Have you created a bounding box for assembly? I once installed Cacheless Search a long time ago and it worked for me.
You should do everything according to the Cacheless Search Deployment instructions.
You can also view the following information in the Solution Center:
https://solutions.industrysoftware.automation.siemens.com/
Search:
It works.
Thank you for help.
Hallo,
what´s the purpose of the spatial filter?
Regards.
I did everything according to the Cacheless Search Deployment instruction but spatial was still inactive.
When I started the utilities below the the filter became active.
  • qsearch_process_queue -u=infodba -p=infodba -g=dba  -force_queue_all_possible_updates
  • qsearch_process_queue -u=infodba -p=infodba -g=dba  -list_queue
  • qsearch_process_queue -u=infodba -p=infodba -g=dba  -process_queue
I would ask for an explanation. Why is working now?
1. Have these three utilities any influence on existing data?
2. Spatial filter activation: do we have to run these three utilities again and again (by changes of BBox values or using another assembly) or once started, is always activated?
Thank you.
Regards.
