Re: Specify the revision of a property or freeze a propertie in a NX Cartouche
Then this decision does not fit. Apparently you will have to go back to testing the version with /freezable
Try to use with different modifiers /master, it's also similar to it that the release status in Teamcenter should influence, as I wrote earlier. I do not really like that there is not a single example with /freezable and to understand how it works it is necessary only experimenting.
/master=both|cad|iman|none
/freezable
Important addition: I found an interesting modifier /write_once in the NX documentation I again did not find its description, but it seems like its name should speak for itself
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#uid:tcint_examples_layout
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#uid:attr_mapping_ugmaster
@ArthurRM,
Good news, I tried with your last information: /write_once and it works well !!!
Thank you very much for your time and your help.
Best regards,
Hello @ArthurRM,
I was continuing with my mapping and I have an "other" issue, it is the same but with another properties.
If i try like that :
DB_CR_USER : owning_user.user.id /master iman /description="Created by user"
DB_CR_USER_A : owning_user.user.id /write_onde /description="Created by user A"
It is not working
If i try with a coumpound property (PropertyA) :
DB_CR_USER_A : itemRevision.PropertyA /write_onde /description="Created by user A"
It is working
Now my problem is how to do the same with the last perform signoff of my workflow  ?
this syntax is working well:
VERIFIE1 : ItemRevision.Job.SIGNOFF(Validation fin projet,Teamleader).group_member.user.person.user_name /master=iman
Now my cuestion is :
How can I do a coumpound property to retrieve that signoff ? It is posible ?
Best regards,
Good afternoon, you mean it does not work? Have you tried this option?
VERIFIE1: ItemRevision.Job.SIGNOFF (Validation fin projet, Teamleader) .group_member.user.person.user_name / master = iman
VERIFIE2: ItemRevision.Job.SIGNOFF (Validation fin projet, Teamleader) .group_member.user.person.user_name / master = iman
Hello @ArthurRM,
Thank you for your reply.
Sorry for the delay, I was on holiday :)
I understand your response but that not resolve my problem.
Example :
Teamleader Signoff Version A = TiTi
In that Case Verifie 1 = Verifie 2 = Titi
and then I revise my ItemRevision to B but when I ralease my Revision with Teamleader Signoff = ToTo
I had:
Verifie 1 = Verifie 2 = ToTo
But what I would like is :
Verifie 1 = Version A = Titi
and Verifie 2 = New version = Toto
Do you have any idea ?
Best regards,
Good afternoon, at the moment I have no idea about this mapping, only if I try to put user in different groups / roles
