Standard object in BMIDE
Teamcenter Rapid Start 10.1.4
I want to apply customer's Naming rule to object Standard, but I can not find it in BMIDE project. I can find Document etc. but no Standard.
Is there any catch?
Or am I blind :-)
Re: Standard object in BMIDE
Colleague find out the problem:
BMIDE dependent template tcx was not loaded.
Solution:set Properties of BMIDE model - activate tcx
