Start a Workflow after the object is saved
Hi All,
In Change Management every user can create a Problem report. A lot of users forget to start a Workflow after the Problem Report is created. How can I start the Workflow after the PR is Created automaticly?
Kind regards,
Menk Slot
Re: Start a Workflow after the object is saved
Builder
Builder
I assume you need ITK to achieve this, that is create an item, then create a workflow.
Thanks for the reaction. It confirms that customizing will be the only solution
