Steps to connect Teamcenter 11.2 to an external web service server
Hi all,
I am new to customization, I need to connect with a post action to an external web service server, I have the wsdl from the web service server with an example of the response I will get, but I read the teamcenter documentation and I only found how to setup a teamcenter web service server and add some new service to teamcenter web service server but in my case I need to connect to this external web service server., I only need teamcenter like a client of this external web service server, in my use case I need to create a new object, in a property I have an ID, with a post action send this ID to the external web service server, and in response I will have several data which I need to put in some properties in the object in the creation process
Please can give me some ligth about the steps I need to do to accomplish this.
Thank you very much for your help in advance, I will wait for any answer.
