Structure Manager is not Working
Hi, is there a reason so that Structure Manager won’t start?
In NX the saving failed with this notification: (original is in german) An error occurred while importing the PLMXML document to the arrangement occurence in Teamcenter.
Any ideas how can I solve this?
Thx in advance
Re: Structure Manager is not Working
Usually means you have an Item Revision in the structure that has an illegal char. It doesn't know how to process it so shows nothing. Review the tcserver syslog to identify the ItemRev then go fix the name/description. Once completed, structure manager will display the BOM correctly.
Evaluating: AW 3.4
Faced similar issue that structure manager is not working when I installed the feature NX integration and the corresponding NX DLLS which are in the corporate server TC_ROOT/bin were not copied to the pool manager TC_ROOT/bin.
may be if you have similar architecture, can give a try.
Phani
