Stylesheet to display Cutom_BItemRevision under Custom_BItemRevision
I have designed a summary stylesheet which displays other item revisions through Objectset with a runtime Property as shown below
<section text = "Reports" title = "Reports">
<objectSet source = "revision_list.Custom_BItemRevision" defaultdisplay = "tableDisplay" sortdirection = "ascending" sortby = "item_id">
<tableDisplay>
<property name = "object_name"/>
<property name = "item_id"/>
<property name = "item_revision_id"/>
<property name = "release_status_list"/>
<property name = "date_released"/>
<property name = "owning_user"/>
<property name = "owning_group"/>
<property name = "last_mod_date"/>
</tableDisplay>
</objectSet>
</section>
As the issue is, the Custom_AItemRevision is pasted under Custom_BItemRevision with a relation when Custom_AItemRevision has a status. Does this allow me to use Runtime Property revision_list to display it, as i have tested it when no status and that works.
Need to valuable input.
Chene
Re: Stylesheet to display Cutom_BItemRevision under Custom_BItemRevision
Any idea on this issue friends. I need your valuable input.
Chene
