Summary tabs: Task to perform: how to add a new a column
Hello every body,
I have a list off tasks in my "Tasks to Perform" FOlder and I want proritize the list based on a column in the summary table.
I would like to add a new column on my table, for exemple "case number" , so then I could based on it to prioritize my list of tasks.
So could anyone give me a clue please?
Thank you in advance for your help.
Best regards,
Re: Summary tabs: Task to perform: how to add a new a column
Each task, because there are a number of different task types in your screen shot, would need to be customized for the "case number" attribute. Then someone would need to populate each task of a workflow to have the right/assigned "case number" would be sorted. Although worthy, I prioritize my work too, this sounds like more work than manually keeping track of it yourself.
Thank you for repling.
Actually I did it simple, I added a new column in the table to display
the property " COMMENTS". In this way, the persone who received the task
will be able to prioritize his list by "case number" that was put it in
the comment.
Surly this solution is very manually, because it needs that the user who
start the task make sure that he put a case number in his comment.
If any one need how to add a column, you can see below:
*the Solution is to customize the stylesheet*
1) check and search for the following preference :( Edit/Options ...)
preference :
TasksToPerform.SUMMARYRENDERING
value:
TasksToPerformSummary
2) Search for the dataset "TasksToPerformSummary"
CheckOut the dataset
Export/Download the named refrences :
TasksToPerformSummary.xml
3) Edit and modify this style sheet in order to add your new column
Delete the named reference and inport/Upload the new one.
