System Wide pseudo folders
We want to use pseudo folders within an item revision.
The Edit, Options, General, Item Revision dialogue allows the pseudo folder to be configured.
But it appears to be a local user setting only.
How do you make it a system wide change?
Thanks, N
Re: System Wide pseudo folders
Create site preferences that match the content of the user preferences. You'll need to be logged in as a "dba" group member to create the site preferences.
Evaluating: AW 3.4
You may want to consider stylesheets instead of pseudo folders, if it suits your purpose.
Stylesheet (display data as a table, list etc) offer all benefits of a pseudo folder (drag drop, cut, copy paste, usability etc) + conditional visibility of data within those pseudo folders.
Harish
