TC-11 Item->Note Owner/Group change through custom ITK client
I wrote a custom ITK client that changed an Item->Note owner,  but failed(access) on changing the group.
My client login is  'hutchens'(group = 'Engineering') and the Note owner was successfully changed to 'infodba'(group = 'dba').   Now,  the Note owner is 'infodba' and group is 'Engineering'.
The Note records continue to show up in the 'hutchens' TC-11 browser,  but they don't show up in the 'infodba' browser.    'hutchens' no longer has access to the Note records,  eventhough 'hutchens' can see them,  but 'infodba' cannot see them.   See attached.
Appreciate any information about how to further manage(Delete,  Update,  grant access, etc...) these Note records.
Re: TC-11 Item->Note Owner/Group change through custom ITK client
Siemens Genius Siemens Genius
Siemens Genius
I would start with investigation which rights and why the users have. The Access Manager for current object is available behind the lock icon in the toolbar.
Note: The ownership has less to do with object shown in navigator. If you chnage owner of an object, the object will not automatically appear or disappear anywhere.
