TC_Arrangement_error_when_used_anchor_not_found
Cannot find this preference, although on GTAC it was part of the solution.
The problem Im facing is in NX anyways:
Error importing assembly arrangement XML document into the PDM system.
Any Ideas?
Thx in advance
3 REPLIES 3
Re: TC_Arrangement_error_when_used_anchor_not_found
You need to create it.  We were plagued by that error until I added it as a Site preference.
Larry Carpenter, P.E.
Hi Larry,
thanks for your reply. Can you please tell me which Category should I use?
Interface.NX?
Doesn't matter.  You can place it wherever you want.  I think I placed mine in "General".
