TC Dictionary English <-> German
Is there a Dictionary to translate the terms used in the English TC to the German TC and vice versa?
4 REPLIES 4
Re: TC Dictionary English <-> German
You can open the file of the textserver in English and German and compare it. Is this waht you want?
2016-11-24 11_07_18-D__Applications_Siemens_Teamcenter_tc_default_lang_textserver_de_DE_cae_text_loc.png
Thank you for your solution, but i have a question here: How can I search for a certain Term?
For example what is Revision Effectivity in German...
with Notepadd++ you can search in English files for revision effectivity in the same file for German language and line you get Gültigkeit des Änderungsstands. Should be okay for a few translations...
Already did that and found it, thanks for your help man!
