cancel
TC RAC programming. How can i apply saved StoredOptionSet to BOMWindow ?
Windows 7 x64;
TC 8.3;
RAC java development (not SOA);
I have a task to bypass recursively configured BOMLine tree.
First i hoped that "SendTo" handler sends expected data from any structure manager to my plugin, but i was wrong.
Now i try to make configuration of BOMLine tree into my plugin, but cant find workable example. Problem comes in a moment of creation Variant Rule, see code below:
rootCmpCtxt = ... //our root component
TCSession session = (TCSession) AIFUtility.getCurrentApplication().getSession();
TCClassService classService = session.getClassService();
TCVariantService variantService = session.getVariantService();
//Get all Revision Rules
TCComponent[] RevisionRules = classService.findByClass("RevisionRule", "object_type", "RevisionRule");
user choose necessary revision rule here
TCComponent revision_rule = ...
//Create BOMWindow with root component and revision rule
TCComponentBOMLine boml_cmp = (TCComponentBOMLine) rootCmpCtxt.getComponent();
TCComponentItemRevision item_cmp = (TCComponentItemRevision) boml_cmp.getItem();
TCComponentBOMWindowType bom_window_type = (TCComponentBOMWindowType) session.getTypeComponent("BOMWindow");
TCComponentBOMWindow bom_window = bom_window_type.create(revision_rule);
bom_window.setWindowTopLine(null, item_cmp, null, null);
//Get saved Stored Option Sets in our component
TCComponent[] StoredOptionSets = item_cmp.getStoredOptionSets(null);
user choose necessary stored option sets here
TCComponent StoredOptionSet = ...
//Get "raw data" of StoredOptionSet
StoredOptionValue[] sosVals = variantService.askStoredConfiguration(StoredOptionSet);
//Set "raw data" to new variant rule (in cycle)
    TCComponentVariantRule variantRule = new TCComponentVariantRule();
    variantRule.setOptionValue(sosVals[i].option, sosVals[i].value);
variantRule.apply(bom_window); //-------------------------------------------------------
Proplem appears in penult line
function expects (TCComponentVariantOption, String), but get (String, String)
and i cant find any roundabout solution.
