TC VIS assembly jt
Hello All.
I created a NX assembly include an ASSEMBLY CUT. I saved it all in TC. JT was created for each part and for the assembly with the geometry of the assembly cut.
However, when I try to load it into VIS, the location of the component with the assembly cut is wrong. It located in the coordinate system position. Attached a screenshot.
Other features as DEFORMATION in nx acts the same.
Please your help
Regard
Eyal.
