TC Visualization Preferences for PDF
Hi everyone,
we are using the TC Visualization Embedded Viewer to view PDFs in the TC Embedded Viewer using the defaultViewerConfig preference: PDF.TCTwoDViewer=PDF_Reference,PDF
Now the PDF will be shown like this:2016-11-15_11h52_09.png
is there a way to configure the viewer that the PDF is initially shown fitted to the width of the frame instead of the height???
Many thanks!
br, Jul1an
Re: TC Visualization Preferences for PDF
I think the settings are going to be client specific and you won't be able to save them for the whole site. Basically, you have to "fit" it once then each time after it should retain the setting. Unless you delete the Teamcenter RAC Cache (stored in a *.cookie) then the settings will be lost and you'll have to "fit" it again.
Evaluating:AW 3.2
Hi Randy,
thanks for your suggestion.
I'll give it a try!
Jul1an
