TC11.4 Custom BMIDE Template deployment fails
I upgraded custom BMIDE Templates from TC11.3 to TC11.4 and it seems to generate corrupted template .zip files. During TEM deployment I get error  "<templateName>_template.zip is corrupted".
Unzipping it with windows Zip function also fails, but it is successfully unzipped with 7Zip.
Has anyone faced this issue ?
Any ideas how to fix this ?
4 REPLIES 4
Re: TC11.4 Custom BMIDE Template deployment fails
If you can unzip with 7zip, can you not rezip it?  Then test it unzips with windows, if that works replace the orignal file and try patch again?
Richard Bennett
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Hello @ProspectPLM,
thanks for your response. But this did not work.
The problem here was too long path to the folder where package was created.
Copied the package to a shorter path and browsed them in TEM. Installation finished successfully.
Excellent, good tip to know!
Richard
Richard Bennett
PLM Consultant
