TCCS Connection error
We have the following multi environment scenario
Application Version : Teamcenter 11.2.1
Test1 server – TCROOT1
Test2 server – TCROOT2
Both the above servers share a common TCDATA location
The web services are used for load balancing and the rich client end users will be assigned based on system availability to Test1 or Test2 server.
Problem
We are able to create custom schedule objects in Test1 but it fails in Test2 with the following error
"Failed to send the service request, encountered a TCCS connection error. Connection Failure: No response received."
Request if you have come across such error and please share if you have any workaround.
Re: TCCS Connection error
Hi Sriram,
Is this issue fixed? If yes, how?
Srivasa
