TCIC CATdrawing dataset to PDF through translation service
Builder
Builder
Is there OOTB that enables the translation of Catia drawing dateset into PDF?
Currently, we do it in TCIC save as PDF back to Teamcenter. Is it possible to do this througn dispatcher translation services with workflow.
What is that translator?
I came across with another post that long time ago, it said there is no OOTB to translate CAT drawing into PDF through dispatcher.
Thanks!
Re: TCIC CATdrawing dataset to PDF through translation service
If there isn't an OOTB translator you should be able to write one using catia API. We recently did the same for AutoCAD drawing. Using the AutoCAD APIs in our VB.Net executable gave great quality PDF output. You might want to explore this route.
Yes there is no OOTB Translator available for the moment.
Either you have to develope the one where need to create customer dispatcher request who will do job of CATDrawing translation into PDF
or other solution is ask the ones who already developed this..  :)
