TCIC unable to map project_list or dataset attr into text area
Builder
Builder
So finally figure out how to map attributes between TC and catia.
I was not able to map project ID/name or attr appear CATDrawing dataset.
I have the mapping difinition as below:
{ Dataset type="CATDrawing"
{ Item type="Item"
"owner" : owning_user.user_name /description="owning user"
"name" : ItemRevision.object_name /master=cad /description="ItemRevision name"
"date" : ItemRevision.date_released /master=iman /description="Date Released"
"project" : ItemRevision.project_list /master=iman /description="project"
"part_number" : Dataset.catiaV5_DWGLink /master=iman /description="part_number"
"revision" : ItemRevision.item_revision_id /master=iman /description="Item Rev"
"definition" : ItemRevision.item_id /master=iman /description="Dokument Name"
Project and Part_number are never mapped. They are not shown in formula in catia see below:
any ideas? Thanks in advance everyone!
Re: TCIC unable to map project_list or dataset attr into text area
project_list seems to be Array property and TcIC dont support this. Does other MCAD support this?
While CatiaV5_DWGLink is relation and not property.
Builder
Builder
Thanks!
CatiaV5_DWGLink is indeed a ImanRelation. I guess that won't be mapped.
But the other method, text area->feature properties set for (Dst catiaV5_DWGLink) did work. and project too..Do not know why attribute link won't work but feature properties will...
In Another way TcIC Generate Attribute File seperately and map to respective properties its value.
It is TciC Own mechanism while Attribute mapping is something standard Tc mechanism to manage.
