TCRA
Hello. I need help with TCRA. The TCRA server stopped initializing. When I try to authorize, I get the message "Server is not initialized properly." Relogin "
Parameters: Windows 2012R2, TcRA version "Teamcenter Reporting and Analytics 11.2.2"
AppServer name & version «Jboss Application Server 7.1.1.Final». Search on the forum did not return any results.
Thank you in advance.
Re: TCRA
Please check your License Server once.
Re: TCRA
checked
Re: TCRA
license server running
Re: TCRA
Check whether the Database and services are up and running. Sometimes DB shows as "Started" in services.msc and not running in background, so it may need a manual startup
Re: TCRA
MS SQL 2012 is installed. The database is started. Queries are executed.
Re: TCRA
It's decided.
The problem was in the Windows security settings.
