TCSSO War Files ( Identity and login files)
 Dear Listers,
Is it possible to deploy the TCSS ( Login and IDentity ) war files on IIS.
Vilas
Re: TCSSO War Files ( Identity and login files)
Not sure if this is possible. As per documentation, war files should be deployed on JBoss and then the IIS should be configured with ajp13 protocol and ISAPI redirector dll which will redirect to JBoss.
https://docs.plm.automation.siemens.com/tdoc/tc/11.2.1/help/#uid:cfgfiles_isapi_2008_H_SE_v1
