TCXML import error
can any one help when trying to change owning user on an orphan dataset using tcxml I get this error
------- Processing island  -------
ElemId    ClassName           Uid                 Status         Comments
Resolve Import Mode:
id13      Dataset             $2LEaac8IFx9YD      SKIPPED        NOTE: Object is skipped as the object is owned by the current site and importer doesn't update local objects
Import Mode $2LEaac8IFx9YD for id13 -> 3
Re: TCXML import error
I don't think this is enough info to help. Is there a reason not change ownership of the dataset in TC? Can you step through each part of your process? Share any of the input file and the exact tcxml command with switches used in your TC CMD prompt?
Jamie Griffis
Mercury Digital Services
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Jamie
thanks for you quick reply I managed to fix my issue about ten minuets ago by using bulk upload and setting the owning site to null
