TEM error while updating to TC11.6
I received following error while updating teamcenter 11.5 to 11.6.
I've already updated the license server to the last version.
any Idea?
Attached log
10 REPLIES 10
Re: TEM error while updating to TC11.6
Good afternoon, try to look at the preference_manager utility syslog in it, you should find a more detailed description of the error
Addition:
syslog must be %TC_ROOT%\logs\subdir or in %temp% directory
@sanchezj, That's a pretty strange error code. Can you start a Teamcenter command window and run:
list_users -u=infodba -pf=D:\plm\tc112\security\config1_infodba.pwf -g=dba
Previous commands ran successfully so its not the password file (pwf). Post any errors from list_users here.
Evaluating: AW 3.4
SNAG-03-01-2019 17.08.32.jpgAny idea??
Looks like a license error. Either the license or the license software or both need to be investigated. Can you review or attach the FlexLM log?
Evaluating: AW 3.4
Attached splm_ugslmd.log, preferences_manager.syslog and install_UPDATER.log
I don't see any issues with the license. The installer failed while trying to create a preference. The preferences_manager util failed trying to load a CAE library. You might not have selected all the features needed given your license includes a whole lot of stuff? I would call GTAC - installation support - to solve this one.
Evaluating: AW 3.4
Good afternoon, try to look at a similar error in the solution center, perhaps this is your case.
https://solutions.industrysoftware.automation.siemens.com/
Search:
Thanks ArthurRM!!!
The solution was in the SFB-TEAMCENTER-8002378.
I have to update firts to AW4.0.1 and Substance Compliance 4.0.1 before update to Tc11.6 Aw4.1
