THIN CLIENT
hi Guys,
I have the following problem, I can login with user and password in the web client but after authenticating and directing to HOME  page it´s stays (see image) loading and loading and there stays with any user.
The tests I've done
Debug jboss
Create a new tc.ear
Clear logs
Re: THIN CLIENT
Have you checked if any of the Java Plugins are blocked? Usually when you run the thin client first time, browser/java application will prompt whether to Trust and run the application.
The prompt could also be hiding behind some windows or is being automatically blocked due to security policies in the browser.
Re: THIN CLIENT
thank's  ManojP,
the problem was this preference WEB_Nav_Items_List
Saludos,
