Tabs in CN properties dialog box mising
the tabs under cn properties dialog box are missing.
the fields listed in other tabs are appearing under the general tab itself.
It is  system specific as we tried the same login in other pc.it is working fine.
Ganesh
Re: Tabs in CN properties dialog box mising
Likely a stylesheet issue. Can you attach some screen shots?
Evaluating: AW 3.4
Did you try deleting the Siemens & Teamcenter folder from %USERPROFILE% and clean up the shared memory directory V11* or V10* and check again.
If that does not work, just to confirm if its a system issue or a user profile issue, try accessing the machine with a different OS profile user and then login to Teamcenter with the same login credentials and see if the issue still persists. This will help to understand if its a system specific issue or if its relating to a profile.
Hi LN,
I have tried thesame you suggested.ASked the user to try with different OS profile..He experience the same issue.When the same profile is used in some other system Issue does not exist..
PFA screenshots..I tried the steps what LN suggested and this is system specific issue.
When Teamcenter isn't able to access a stylesheet it defaults to a list of properties (like your first screenshot). Have the user run genregxml.bat to see if that fixes their issue.
Evaluating: AW 3.4
Hello
Do you see any errors in the client's Console?
It might give more details to debug the behavior.
Mahendra
