Taks leftover. TC11.3.0
Hey,
After finnished sample workflow I have still one taks to do but nothing is attached to my Worklist.
How to reflresh it to make this 1 undone task gone?
Re: Taks leftover. TC11.3.0
Try "View - Refresh Window" to update all objects in session.
If not, login as infodba, make General search for Type= Inbox and Owning user=username.
Delete the users inbox object.
When the user logs in again the inbox will be automatically created and hopefully the task is removed
BR,
Morten
This is working workaround but.....it deletes subscriptions also...
This bug was reported since TC8..... Siemens create ER on this but no patch was released yet.
