Task Notification Handler - customize email template
i need to customize the email template that my workflow sends with the Task Notification Handler.
There is a file that i need to modify?
Thank you!
3 REPLIES 3
Re: Task Notification Handler - customize email template
I guess this is standard. Could not change the template. If you need new template then you need to design a Handler.
chene
Hi Chene, thank you, but how to create a new handle?
Use ITK reference documentation for creating a new handler. I dont think just that will serve the purpose for custom email template.
Chene
