Tc Classification
Hi All,
We have introduced TC Classification module and started classifying the ITems
Now we want to send the classified item attribute values to our Parts catalogue system.Could you guys please help how we can extract the value for an classified items from TC and send it to another system..
For eg: As shown in screenshot i need to send the Item ID and the Classification propeties to different system
Thanks in Advance,
Raj
Re: Tc Classification
In Classification, select the class you wish to export, click the Export Objects icon from the toolbar, select an appropriate traversal rule (e.g. ICSExportICOs) and provide a filename. The output will be an XML file containing the data defined in the selected rule.
Patrick (Pat) Kennedy, Sr. PLM Application Engineer, Acuity Solutions
Thanks a lot Patrick.
Will try it .And I hope after export we can use this file as source for our third party softwares
I tried it but that wont give the details of Item and its classification property.
I need to extract the Data of the classified Item along with its classification property.
Basically my requirement is once the Item is classified ,i need to have an Schedule job or somekind of job that extract the Item data like Number and the Classification properties of that Item,so that we can insert this data into diferrent software database.
Then you'll have to experiement with the other "Target Application" traversal rules. MRMAssemblyExport may get you what you want.
