Tc related 'error' in NX log file
Testing NX 11, so I've been going thru the log file to see if anything is going on, or not going on, in the background, and I came across the following
    TCIN SOA operation object name: CNGAAQ9lY1_PGB:ClFAAQ9lY1_PGB:g4JAAAcsY1_PGB
        Error: 100000001, (TC 38015): Unable to find a property with name CGR4_Item/cgr4_site.
        Error: 100000004, (TC 60007): Cannot resolve property "cgr4_site" on "NX11 Sheet Metal save-as Test" of class "CGR4_Item" (tag 0001607a)
        Error: 100000003, (TC 215086): Resolve dataset attribute value using item revision failed (60007).
 To my untrained eye, it appears some attribute, or other Tc thingy, named "cgr4_site" is not mapped correctly?  cgr4_item is our custom item type.
Should I be concerned?  we are looking at a Tc upgrade to Tc 11 also, so this would be a good time to visit, and correct any issues there.
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: Tc related 'error' in NX log file
Perhaps cgr4_site is a mandatory field (cannot be blank) in Tc but wasn't filled out in NX when doing the save-as?
Evaluating: AW 3.4
I bet that's it, thanks!
-Dave
