Tcserver not working
Hello everyone
I got a problem....
When I start TC
tcserver will be start but few seconds later
It will disappear like pictutr 1(07_x07_13-49.33.png)
few seconds later
It will start like pictutr 1(07_x07_13-49.56.png)
and keep this loop all the time
I try restart tcserver and fscserver and sql but not working
How to solve this problem?
thanks
Best Regards
David
Teamcenter 11.4,Active Workspace 3.4
Solid Edge ST10
Re: Tcserver not working
Are you getting a tcserverXXXXXX.syslog? Many things can be the cause like authentication, java, shared memory or a missing %TEMP% dir. You can try shutting down Teamcenter then deleting the shared memory dir before starting up again. The syslog might give you a better idea of what is happening.
Evaluating: AW 3.4
