Teamcenter 11.2.2 and Plant Simualtion 13.0.2 integration
I installed the TC11 TEM Package on the server side without problem.
When I try to connect to Teamcenter in Plant Simulation get the following error:
(Teamcenter 11.2.2; Plant Simualtion 13.0.2; Four-tier environment)
For the server URL I try to give the address of the web server (http://TC-01)
Thank you for your time!
Best regards,
Re: Teamcenter 11.2.2 and Plant Simualtion 13.0.2 integration
Problem solved: "http://WebServerName/tc" (without port number) works well
